I recently converted an .avi file to dvd using DVD2SVCD. After authoring the dvd and burning it to DVD+R, I popped it into my player and discovered that I have scrolling video. The picture just keeps scrolling through the screen. The dvd plays fine in my computer. The tv works fine both when watching cable or other dvds, as I tested that tonight right after. My only thought is that the original file was in PAL format, which might not be compatible with the player. I have played SVCDs in PAL format with no problem however. Does anyone have any ideas?
Well I used Virtual Dub on the original .avi file and that displayed that it was 25 fps. At that point, I went with the PAL format for encoding and authoring.
What is the source of the AVI? If it was DV, I remember reading forum postings about the setting for TFF. You may need to reverse that setting and then re-encode.
How to Create Scrolling Subtitles on my Videos?
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 7th Dec 2013, 10:17 -
How can I have mpg with scrolling text?
By RBCC in forum Newbie / General discussionsReplies: 7Last Post: 25th Jan 2012, 05:48 -
scrolling picture problem with svideo
By slyder0244 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jun 2009, 19:35 -
scrolling / running watermark on videos
By greendesert in forum Video ConversionReplies: 7Last Post: 3rd Aug 2008, 01:19 -
No scrolling after edit with MPEG Video Wizard
By rockethobbit in forum EditingReplies: 9Last Post: 23rd Nov 2007, 13:31
