  1. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    I am making photo slideshows on dvd.
    I would like to play the slideshow and be able to change the background audio.
    I want to have different albums as the audio
    let the user choose what he wants to listen to while viewing the slideshow
    thankyou
    Apr 2004
    Miskatonic U
    You have a couple of choices, depending on what authoring software you use. If your authoring software allows for multiple audio tracks, then simply add the tracks and create buttons to select the one required.
    If your authoring software does not allow mutliple audio tracks, then create multiple versions of the slide show, each with different audio tracks (just reuse the slideshow video and mux in different audio)
    Read my blog here.
  3. Member Sifaga's Avatar
    Aug 2003
    Hey guns,
    i tried the multiple versions of the slideshow approach b4 and it worked ,
    i would like to try the multi audio option.
    Im going to try ulead workshop, are there any other recomendations
    with the multi audio , will it toggle thru the audio tracks when i press the audio button on my remote , the same as DTS and 5.1 sound
    or would there be different buttons for different audio
    thankyou
    Apr 2004
    Miskatonic U
    You can toggle through, but this isn't very user friendly. It is easier for people using the disk to have a menu to choose which track to listen to. I haven't used ulead, so I don't know how it handles it.
    Read my blog here.
  5. Member Sifaga's Avatar
    Aug 2003
    Hey Guns,
    if you were to try this little project which authoring software would you use.
