I captured analog TV with the capture feature of "Main Concept MPEG Encoder", using the "NTSC DVD" format. How then do I burn that resulting mpg file?
When I try with Nero, it tells me that I can only burn an ifo, vob, or bup file to a DVD. If the file needs to be converted further, then what's the use of capturing in the "NTSC DVD" format to begin with.
Thanks in advance for any help.
You need to "author" the mpeg-2 file to make it DVD compliant. Look for the guides on the left for "authoring" and you'll have your answer.
t
next to the 8mm tape whats the best way to store "raw" captured f
By st711 in forum MediaReplies: 2Last Post: 25th Dec 2009, 22:58 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
WMV has no video on my TV out on "WMP v9 (VC-1 Simple/Main)"
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2008, 05:08 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 13:00
