I'm thinking about getting this dvd compling tool. Does anybody know anything about it. Is it good & how much is it ? Where can i get it. Any help would greatly be appreciated....
I really hate to say this because I use to hear it all the time but Suga you got to READ ...go to the tool section or do a search . . but to give you a break... it was a powerful tool a bit confusing at times because I did not have a manual, I had to do trial and error. but that was many years ago and I do not know how compatible it will be with new programs or components
1. yes - there are guides on the web, there are tons of posts here.Originally Posted by sugarshine
2. it was state of the art in it's day, and it's very powerful, but also probably more complex than the average user needs.
3. very expensive - was $30,000 when new and cutting edge, and still sells for $2-3,000 on eBay.
4. eBay.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
There are still dealers that carry it, but be prepared to spend a pretty penny. Unless you're doing complex authoring, or doing commercial titles, you would be better off settling for something else.
it comes with a very good manual - it still works today on anything - except you need new dongle drivers for xpOriginally Posted by CoasterCreator"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Maestro is THE Business, I can do anything with this baby and it isn't out of date in relation to today's stuff because the DVD spec is set in concrete until the day they bring out DVD2 or whatever.
This software gives you total control over the format which even new apps cant even come close to except obviously Scenarist etc.
If you can get it, GET IT.
Obsessed Maestro fan.There are 10 kinds of people, those that understand binary and those that dont.
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
