The JVC SR VS30U is JVC's best VCR for dubbing as it has a Firewire out port so that you can capture the video/audio directly to your hard drive.Originally Posted by ejai
It also has the standard S-VHS out and RCA jacks. The unit can also transfer video directly to and from the built in DV deck.
Results 61 to 73 of 73
Hmm........I shouln't have had those Refried Beans with lunch!
ejai,
GOOD NEWS for you my friend: you can order JVC HR-S9911U (top of the line S-VHS machine with TBC, 3D DNR, 4MB frame memory...) for $249.99 and $374.00.
Go to: http://www.ecost.com/ecost/ecsplash/search/search.asp?Search=JVC+VCR&CurDSN=simple&cal...=1&incimage=on
Good luck! -
There it is for all to see, spending more does not get a more reliable machine.
This is true my friend, but I have no choice. Believe me I'm tired of buying additional equipment. I could of paid for broadcast equipment with all the add-ons I've purchased in the last 2 years.Originally Posted by samijubal
I do like the JVC M10 but it has issues as well. That is why some of the people who have this machine have purchased video enhancement equipment to fix some of the shortcomings (me included).
My biggest problem with the M10 is the video looks too soft and the dark areas aren't true black, more like resin black. What I like most about the M10 is it's noise filtering on some older tapes.
Thanks Zorankarapancev I will look into that.Do unto others....with a vengeance! -
hmmmmmm I wonder if the Firewire output can be connected to the DR-M10's Firewire input.Originally Posted by rowchar
I do like the noise filtering too, but I wish I could turn the noise reduction on and off like the Panasonic. It's great for videotapes, but my satellite doesn't need it and having it on just gives it more of that digital compression look.
I agree, The Panasonic looks sharp most of the time but it has a chroma problem and that is one of the reasons I sort a different recorder. I have learned one thing and that is that using the composite instead of svideo on the Panasonic looks better in terms of chroma. I'm not sure if that will work for everyone but it does for me. Also the Panasonic's filters take away the detail but will sustain the sharpness.
I use a video enhancer to help get the picture quality I need.Do unto others....with a vengeance! -
I need to convert a series from videotape to DVD. It's 170 episodes and I want the quality as good as possible, but I probably wouldn't do much else in the way of videotape transfers. So how much better would the copies be with an enhancer? Would the recordings be enough better to justify the cost? They are in EP and so are not very good as far as sharpness, is that adjustable with an enhancer. What's a good brand? That's an overload of questions I know, but I've never used an enhancer and wonder if it's worth it for how little I have to do.
You da man! Thanks I will definately do that. I just bidded on a Vidicraft Detailer III because I have an older model.Originally Posted by gshelley61
Thanks again.
ejay,
Try this: connect your new VCR to a Panasonic DVD recorder. Take the output from the Panasonic and connect it to a JVC DVD recorder. This way you will be able to use the Panasonic's TBC and eventually to correct the video signal. See what will happen, you can't lose anything... -
I tried that as a quick and dirty method to adjust the black level. It added noticeable digital processing noise because the signal is being passed through two complete digital video processing circuits (one in the Panasonic, and one in the JVC). If the VCR also has digital signal processing (many do) that's three...
Too late, I took the new vcr back for a refund. I am now going to get a more better model. 8)
Looking for info re three old VCRs - two JVC and one Fisher
By wiseant in forum Capturing and VCRReplies: 2Last Post: 23rd Jul 2024, 13:01 -
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 555Last Post: 1st Jul 2013, 12:33 -
HOT DEAL: St. Louis Craigslist - $75 JVC DR-M10 DVD Recorder
By jbd5010 in forum Off topicReplies: 2Last Post: 16th Mar 2011, 09:21 -
problem recording with jvc dr-m10
By restauroman in forum RestorationReplies: 3Last Post: 28th Feb 2010, 12:47 -
JVC DR-M10 help
By colt4523 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2008, 07:53
