Using Mainconcept to convert files to DVD, is there any benefit to quality by raising intra-dc precision to 10 or is 8,9 better? I thought I read recently that 8 was better in Mainconcept while 10 was best in TMPGEnc but I can't remember where. Thanks
Typically, this value doesn't have to do with each encoder individually but with the encoded video characteristics and selected bitrate.
At higher bitrates (>6Mbps) it's much better to use 10bits precision. At low bitrates, higher DC precision defeats the purpose and will probably give worse results.
I personally use 10 bits for AVG 6Mbps and above, 9 for 3500~4500 and 8 bits for low bitrate encoding (e.g. 1.5Mbps for quarter size frame).The more I learn, the more I come to realize how little it is I know. -
Exactly.
I use only 8bit on both encoders, because when I encode to 1/2 D1 (352 x 576) I never go higher 4000.
When you use 9 or 10 bit with lower (<5000) bitrates, you end up with a more smooth picture and more macroblocks. Only CCE is an exception on thing (there you have something called "mosquito" noise, which some people find it better than macroblocking)La Linea by Osvaldo Cavandoli
CCE tends to generate noise before encoding, which creates what looks like a film effect. In general, CCE will smoothen the picture before encoding in low bitrates avoiding the macroblock visibility.
I believe that the best benchmark video for testing the DC precision values is one with a close-up on a human face or a very dark scene.
A low DC precision value will create very visible boundary effect. If you need, say, 20 different shades of grey-to-black to encode the dark scene, a low DC value may give you only 4 while a larger may give you 15 or so.
Higher DC precision takes up more bits and requires a higher bitrate.The more I learn, the more I come to realize how little it is I know. -
Actually, while I'm here, one more question please. In Motion search pixel movement, would there be any quality increase seen in a file over 5500 bitrate by going above values of 7? Thanks again
There are two sliders there. One is for motion search range and the second for motion search mode.
Setting search range to more than 16 is outright useless. A value between 8 and 10 should be considered a realistic max.
In motion search mode, the higher the value the slower the encoding and the better the result.
However, values above 20 seem to only deteriorate performance. I use 16 there (actually set both sliders to the middle - almost).
Practically, the defaults of the encoder seem to offer the best balance between speed and quality.The more I learn, the more I come to realize how little it is I know.
how to extract I (Intra) P (predictive) & B (Bidirect) Frames from video?
By tnwmn in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 22:57 -
onBoard Video Recording - Precision/Performance cars
By marinpa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Feb 2011, 01:37 -
Dell precision 2300
By pantangs in forum ComputerReplies: 0Last Post: 30th Oct 2009, 13:46 -
View intra DC precision
By Bergen in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 09:20 -
Precision Acoustics powered subwoofer
By johns0 in forum Off topicReplies: 5Last Post: 29th Jul 2009, 21:22
