I have a project done using DVDit. The total size is 5.08 GB, I know I'm over the limit to burn to a single layer recordable. What I'd like to do is create a DVD folder using DVDit and then use DVDshrink on it accordingly to get it down to 4.37 GB.
There's a custom size field in the video specs window, what value do I enter to make it work?.
Does anyone have experience with this?
Choose Reauthor, then choose the automatic settings.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Originally Posted by Forum Troll
Anyway, in DVDit! go to the PROJECT SETTINGS area, and enter in the number in megabytes (9000 is good) in the output size, then press the ENTER key. It'll pop up as "User (8.79GB)". I have this on mine, so I can author as large as I need.Want my help? Ask here! (not via PM!)
thank you lordsmurf !!
it's so obvious when you think about it - rather embarrasing..... -
Originally Posted by CoopWant my help? Ask here! (not via PM!)
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 14:18 -
Computer Wind XP Folder question???
By rrtbusa in forum ComputerReplies: 2Last Post: 5th Nov 2008, 08:07
