I'm on my way out to best buy from work. We need dvd's. What is the most reliable DVD for a commerial product? I'm leaving in 15 minutes, so a quick response would be greatly appreciated.
Thanks a ton,
Mongoo
Results 1 to 12 of 12
Mfg wise go with SONY, FUJI, MAXELL
Fuji Japan will be TY's or Maxell's
Fuji Taiwan will be MCC's
Maxell Japan will be TY's or Maxell's
Maxell Taiwan - not sure... avoid
SONY Japan should be good as well
If you can find Apple.. .buy them too. -
Maxell could be TY or Ritek G04. Go with the Japan Maxells and you'll get the TY
How will I know if they are maxwell japans?
I'm just going to best buy. These are discs we make and send out. So they must burn well and play in many players.
Also should I get + or -, again most compatible for video.
Thanks -
The package will say where it was made ...somewhere.Originally Posted by mongoo13
For safety in compatibility, I suggest you go with -R media. -
apple dvd-r disks are always good
Fuji Japan (TY's) are good"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Okay, first off I'ld like to thank everyone for the help yesterday. Upon my arrivel to best buy I saw that none of the DVD-R's by Fuji, Maxell, & Sony where Japan made. Instead they where all Taiwan.
I did however find a 50 pack of Fuji DVD+R Japan made. So my question is to you....
Should I bring back the DVD's and shop around for Japan DVD-R's instead of + R. Or is the Fuji Japan +R's still pretty safe as far as compatibility goes. Like I say we ship our product cross country.
I should note that we have a TDK +/- burner so that is not an issue.
Mongoo -
The whole + and - thing.
In the beginning .... as the story goes... -'s were a tad more compatible (especially with older machines). I think it was 95% compatible and +'s were 90-92% or some thing like that.
Now the machines being built today are better adn will pretty much play most anything you throw at 'em. So it depends on your machine and what you will do with the disks.
Your consumption only on newer machine... keep 'em -- they will probably work
Planning to share with fam or friends... get -r's
IMHO -
Well, What do you think is better in terms of compatibility.
1) Fuji DVD+R Japan
or
2) Maxell DVD-R Tiwan
I've got these to pick from right now and need to send some stuff out.
Mongoo -
Fuji "made in Taiwan" are PRODISC media anyway, so those would have been just fine.
Same for current Verbatim "made in Taiwan" are MCCRG20 media, also good.
That's about the best you can get at a store these days.
Hunt down APPLE discs from an Apple store for the best you can get.Want my help? Ask here! (not via PM!)
I suggest the following:-
- Stick with your + discs, and send those out. In the meantime, order the Japan-Maxells from an online reputable store.
- If you get any complaints that appear to be attributable to compatibility issues, simply appologize and send out a replacment disc with the (-) discs, which you should have recieved from the online store by then.
-If on the other hand u do not get any complaints, then u can use ur new stock in the future, and u wud have effectively conducted a market study for urself, as to what best fits ur needs.
Good Luck.
Most reliable BD-R media?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 14Last Post: 26th Apr 2012, 09:24 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 14:10 -
Is RICOHJPNR01 media reliable??
By Super Warrior in forum MediaReplies: 7Last Post: 24th May 2008, 09:43 -
Reliable +R DL media?
By Sephiroth666 in forum MediaReplies: 16Last Post: 4th Jan 2008, 04:42 -
I need a 100% reliable burner and media.
By sneaux in forum MediaReplies: 36Last Post: 17th Jun 2007, 18:00
