When I resize with VirtualDub, it has a "Nearest Neighbor" selection that is set as the default. Should I change this? I've heard of bicubic resizing and linear resizing, but I don't know what these things really mean.
So what about the other Filter Modes: Bicubic, Bilinear, Precise Bilinear, Precise Bicubic (A=0.75); (A=0.60); (A=1.00), and Lanczos3. What do these mean, and how and when should you use them.
they are all types of resizing algorithms - there are many more.
Nearest Neighbor is about the lowest quality, and is the lowest quality in vdub options
for downsizing - try bicubic or lanczos
for upsizing use lanczos.. which is one of the best resizing methods - vdubs lancczos filter is extremely good , better than photoshop (which uses bicubic or photoshop cs (which uses Bicubic Smooth)) ..
it takes longer as you use a better algorithm though -- though i hardly notice much difference ..
for upsizing you should not go more than 10-15% at a time and keep repeating -- you can stack these filters in vdub.
you may have to use a sharpen or unsharpen mask/filter on the results - often going just a touch to much , then using a very tiny amount of blur (i dont think you can do this in vdub though, vdubs blur is to strong, but a 2d cleaner may be used sparingly perhaps) .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello,
Sorry can't help with those. I just stick to the original source aspect ratio whenever I fool around with it.
Kevin
--Check the guides on the left of the screen <---- One should have something on resizing--Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
resize filter in virtualdub for upsizing videos
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2011, 06:26 -
I Don't Understand video language
By capnralls in forum SubtitleReplies: 4Last Post: 29th May 2010, 10:09 -
I don't understand why I can't edit my .mp4 videos?
By JohnBarnshaw in forum Newbie / General discussionsReplies: 10Last Post: 13th Jan 2010, 18:43 -
/shrug - Now What Don't I Understand
By macbuz in forum MacReplies: 2Last Post: 12th Jan 2009, 17:21 -
Still don't understand .avi to DVD input/output
By sknox in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jul 2007, 13:51
