  1. Ok, I need some help. I have MyDVD 5 deluxe and used to have Ulead (I think) Movie Factory 2. Anyways, when I added an .avi (divx or xvid) video to my MyDVD project, it only allows me to get like a little over an hour of the video, then it says the disc is full. On the other hand, when I had the Ulead, it let me add, not sure of the exact amount, but seemed at least 2 - 4 hours worth of the same type of file.
    So leads me to my questions:
    1 - Why the difference in the two softwares?
    2 - As I understand, mpeg2 files are like DVD files or something? I know it allows me to put much more film in the MyDVD project.
    3 - How big would a normal 700 MB Divx movie be if I converted it to MPEG2. I would do it so I could fit the movie, or any other avi video for that matter, onto a single DVD+R yet still use MyDVD. (any suggestions for the software to use to convert would be apppreciated)
    4 - Is there any software you would suggest for burning DVD's that would allow me to use the divx/xvid files, kind of like how the Ulead software I described earlier worked?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Mpeg2 is the dvd video standard. This is what must be loaded into a authoring package before making a dvd. The divx file will be whatever size the bitrate determines. Use a bitrate calculator found in the tools section to the left <----.
    You can also browse the tools section for avi-mpeg2 conversion software. Also, check here for instructions:
    https://www.videohelp.com/convert
    Kevin
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    see the dvd specs - unless you have a dvd player than can play divx , dvd's have to be mpeg2 (or mpeg1)
    how much you can fit depends on the bitrate
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    The amount of dvd compliant mpeg video you can put on a DVD depends on the size of the video (720x480 is the largest and 352x240 the smallest) and the bit rate.
    Smaller video size and a smaller bit rate will produce a smaller file size at the expense of quality. I ran a test where I would have been able to fit 25 hours of DVD compliant video on a single DVD. Not very practical though because the quality wasn'y that great.
    Look in your video settings to adjust the birate and the video size. Using 720x480 with a variable bit rate of 6000 will produce good quality files with about 1 1/2 to 2 hours on DVD.
    Nov 2003
    Moreno Valley, Ca
    Depending on what your intended playback device is:
    For playing back on a standard tv, not a projection/large screen you can safly use a resolution of 352x480 and reduce the bitrate accordingly and still retain the same quality playback.
    352x480 at 2 mb/s will look the same as 720x480 at 4mb/s as viewed on a standard tv
    not exact, but in general
    2 mb/s = 4 1/2 hr
    3 mb/s = 3 hr
    4 mb/s = 2 hr
    audio sample rate will affect this some
    The older version of MyDvd (3.5 I think) captured raw audio which made the file large. It also added a "egg" to each disc which took away from video capacity. If it works for you, fine, it did not for me, much prefer Ulead which came bundled with all 3 of my capture devices
