Poll: What do you do with your AVI or MPEG files once converted to DVD?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 22 of 22
  1. Member VideoTechMan's Avatar
    Apr 2003
    Michigan, USA
    I still have my AVI files on my hard drive, but trying to figure a method to save them for future use so I can get back my HD space.
    VTM
  2. Shouldn't this be a poll ?
    Edit - I save mine to DVD-R.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  3. Member VideoTechMan's Avatar
    Apr 2003
    Michigan, USA
    Yes, but I cant seem to get it to show up, or maybe its something im not doing right .
    EDIT: I just figured it out....after reading Capmaster's errors on the Housing thread, I suddenly figured it out.
    VTM
    I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
  4. Would delete them due to size but I work with MPEG's only and they are reasonably sized to store.
  5. I delete the avi files, but keep the original tapes.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    NO AVI! I have the hauppauge wintv pvr250 so I only have mpegs to work with. I don't even do divx anymore since I have a nice single layer dvd burner .
    Kevin
    EDIT - No broadband either so I don't download avi's off the net to convert
  7. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Depends on the content for the most part I only use a DV tape once and keep it. I don't tape much but the stuff I do is worth keeping, I make an additional full backup of the AVI to disc, splitting it into parts where neccesary.
    Same thing with my VHS AVI captures.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I delete them. Mind you I've been burnt a few times
    If in doubt, Google it.
  9. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Backup to a rewritable! Than just erase it after your projects ok.
    Kevin
  10. Banned
    Jan 2004
    Going in Circles
    I delete them
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You must have missed the joke. I've bolded it
    nah, just kidding
    I'm one of those happy go lucky people that just shrugs their shoulders and says "oh well" when things like that happen. I mainly deal with TV caps into DV via an ADVC-100 and the 75GB files are a bit hard to backup to a RW
  12. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Ahh... 75gb would be difficult. Forgot about UNCOMPRESSED avi's.
    Kevin
  13. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    depends on the project - if it's something for myself, and I'm satisfied with the finished product, I'll delete the .avi files.
    if I think I might want to do something else with the footage, or spend more time cleaning it up, I'll keep it on the hard drive.
    if it's for a paying customer, I'll archive the .avi files on dvdr. so far, space hasn't been an issue, but if it is, I'll start adding in a data-retention charge and pick up an extra hard drive for storage of their project files.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  14. Member CoasterCreator's Avatar
    Aug 2004
    somewhere in time & space
    1. I erase avi
    2. Make a coaster
    3. have to start all over again
  15. Member yoda313's Avatar
    Jun 2004
    The Animus
    Originally Posted by CoasterCreator
    1. I erase avi
    2. Make a coaster
    Hello,
    Haven't you learned anything from this website yet???
    Kevin
  16. Member Grimey's Avatar
    May 2004
    Canada Eh?
    I leave all mine on my hard drive, excpet now i'm starting to run out of space, so i might have to go and put a bunch on discs or just delete them.
  17. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I delete lesbian-gore-fest.avi once lesbian-gore-fest-edited.avi is created.
    I then delete lesbian-gore-fest-edited.avi once the mpeg is authored to dvd, and the mpeg backed up to a seperate DVD-r.
    Each of my avi's are 13gb/hr; impractical to archive.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  18. Member yoda313's Avatar
    Jun 2004
    The Animus
    Will
    Hello,
    Ahh.. PRon redundancy, very good in case of accident
    Kevin
  19. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    I save really rare and a few favorites on HDD. The rest I delete. I have extra drives laying in storage, like CDs, but I really should mark and catalog more of them as it's difficult to remember what I saved on which drive.
  20. I mostly capture directly to MPEG with my All-In-Wonder - I'll capture as AVI if I plan on adding some fancy effects or doing some creative editing.
    Usually delete the AVI files - I'll archive some as data (using a file splitter if they're too big for one disc)
  21. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I capture from digital cable box with advc-100 in avi format then convert with TMPGE PLUS & DVD AUTHOR then do a test burn with NERO BURN on a DVD+RW to see the quality. If it's good then I go ahead and delete the avi file. The avi files are way too big to keep on my hard drives even though on 1 pc I have 500 gbs of hard drive space!
  22. Member Heywould3's Avatar
    Apr 2002
    always on the move
    90% of my files are DIVX or i convert them to divx.. i do keep dvd img as dvd/vob but all my other stuff like tv shows i record is divx.. i thn burn to DVDR. as data.. my phillips plays dvdr with avi/mpg/dat etc as data so i dont need to convert. handy feature..
    BUT after they are on dvd or cdr i delete off computer
