tools required: virtualdub or virtualdubmod 1.4.10.0 or vdub-mp3-freeze AND a bmp program like paint
note: in our discussion we found out that xvid can only be reliably joined using virtualdubmod 1.4.10.0 only, and if you xvid has VBR just check the box Nandub VBR MP3 compatiabity mode in the open video screen. if you have a divx file with VBR you may use vdub-mp3-freeze.
1 using your bmp program make a bmp of the info you would like to include
2 open full clip in virtualdub, virtualdubmod 1.4.10.0, or vdub-mp3-freeze
3 mark the start point and end point of intro cut (use keyframes only)
4 set audio to direct stream copy and avi audio
5 set video to full processing mode and
choice correct compression to match clip (found by file-file information) and
add logo filter
5 save as … intro.avi
*this is the only reencoding done so it is very fast (usually 5 sec for a 10 sec intro - this can vary)
6 open your new created intro clip
7 append original clip
8 set audio to direct stream copy and avi audio
9 set video to direct stream copy
10 save as ... XXXX.avi
* as you can see it will take only 45 secs for a 41 min clip since there is no reencoding at this point
Results 1 to 1 of 1
I Need Black Bars On my Xvid Clips
By hech54 in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 11:05 -
Avidemux - joining two Xvid clips resulting in one Divx video, why?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2009, 16:10 -
VP7 to xvid: Is it possible? Is it easy?
By EAO in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2009, 12:38 -
best and easy way to create a xvid from LAVC
By Cazz in forum Video ConversionReplies: 16Last Post: 14th Oct 2008, 13:34 -
two or more video clips (xvid) to DVD?
By kthan in forum Video ConversionReplies: 9Last Post: 3rd Aug 2007, 21:01
