Hi!
Well, I'd really appreciate your help with this issue.
I have a problem playing ANY video on my computer.
Doesn't matter the format: Divx, Xvid, Mpg, Asf... it's all the same.
The specific problem is that, sometimes, during playing, there are some "jumps" in the image. For a second or two, video plays 2 or 3 times faster of what it should, so I miss details or dialogs.
Strange thing is that I've played with every possible codec and every possible player. Installed k-lite codec pack ONLY with the codecs I knew I use. Didn't work. Installed ffdshow... same. Instaled k-lite codec pack AND ffdshow... same. Installed nero video decoder... well, you know the answer. Installed standalone xvid decoder... same...
Played my videos using WMP 9, WMP 6.4, WinDVD, Nero showtime... SAME!!! :@ Reinstalled nvidia detonators, installed OLD detonators, installed LATEST detonators... No use.
Btw... in the video renderer statistics, it allways says "0 dropped frames"
Can't think any more solutions...
Help, please!!! Dunno what to do. I'LL REALLY APPRECIATE ANY OF YOUR HELP!!!
Thank you.
Does this happen when you play them on your standalone?Burn a S/VCD or DVD on a RW disc.
If it doesn't it could be several reasons:bad HDD,bad videocard,DirectX is corrupted,DMA is disabled,codec conflict,etc. -
Well, this doesn't happen if I play the movie in ANY other computer. At office is just fine. I've tried in a couple of friend's computers and they work just fine. The problem is only with my computer.
Checked hdd for errors, and made a full diagnosis using Sandra 2004. DMA enabled, erased all codecs and reinstalled one by one.
What else could I do? -
If you have an onboard audio card, disable it and put in a generic soundblaster generic card or whatever. It worked for me.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Problems with Adobe dropping frames in imported video
By Texas in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2010, 14:25 -
AVS Video Converter 6.3 dropping frames
By LLavelle in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 17:35 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
