Hi, i have a question here...
http://forum.midiaddict.com/viewtopic.php?t=47095
Also, i will soon have a centrino laptop with a dvd writer and i want to be able to put the 18 mpeg2 files on to video cassete. I have a stereo nicam video recorder with av connections (video and stereo sound), it also has scart and arial inputs like standard players, how can i set up to record the 18 mpeg2 videos from my laptop to video? I need them to play with no gaps, (im putting them on casset for a freind who wants my dvd in america, and i cant get my dvds working, cassete is a better option for me anyways over dvd.
Thanks all.
WB
Censored Rage forever
It really isn't that hard to create a custom DVD with the basic features you require using a program like TMPGEnc DVD Author.
For VHS, your laptop's graphics card would need to have video out on it. Most have either composite or S-Video which can go into most VCRs given the correct leads AFAIK. That said, I don't know whether the quality of output from Video Out will be that crash hot.
Ideally you should be using something like the ADVC-100 I would've thought.If in doubt, Google it.
video cam can suite 8mm tape/cassette
By happytony in forum Video ConversionReplies: 1Last Post: 24th Aug 2011, 00:33 -
By happytony in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Aug 2011, 23:55 -
Recording from Vhs cassette With best video Quality.
By nusratjaveid in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2011, 20:23 -
need some advice on some svhs and video cassette recorders
By gnrforever in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 16:57 -
How to convert 8mm video cassette to DVD
By greg555 in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2007, 04:45
