Hi,
Ive downloaded and I want to join 4 *.wmv files together to make one single one but im lost as to waht to do , it looks very complicated and i didnt see anything in the prog to help me joining files togehter, am i overlooking something simple or is it the wrong application, a few ppl here said it would do the job i require tks in adv ,
dosie
dosie,
Use VirtualDub. Open file 1, the go to File --> Append Segment, select file 2, then repeat as required.
Go to Video and select "direct stream copy", then go to Audio and select "direct stream copy". Then go to File and "Save as AVI...".
It will take anything from a second to a minute to output your new, totally-joined file.
Hope this helps!
Cobra -
You might need Virtualdub 1.3c to join WMV files.
He's a liar and a murderer, and I say that with all due respect. -
Tip - Anything AVI-related, VirtualDub should be your first port of call. It's a fantastic bit of software - like a Swiss Army knife for video enthusiasts.
