Results 31 to 40 of 40
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
It's the card, not the video source.
The hell of it.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I have the Resampel audio checked but not the streams one. Do I have to have both enabled?Originally Posted by sacajaweeda
LS -
Capture something with the resample audio dynamically option checked. THen open your captured AVI in VirtualDub and pull up the file info. Compare the stream lengths. If they are different, enter the difference as your delay offset. Positive or negative value, depending on which stream is ahead of the other.
HTH"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
This one time I can say you are wrong.Originally Posted by lordsmurf
I just did some testing over the weekend. I captured 2 hours of broadcast from my cable channels. No sync issues at all.
I captured video from a VHS tape and no sync after 1 hour.
I captured from a BetaMax tape and it has sync issues after 30 minutes.
My Hi8 has sync issues after only 8 minutes. I've been capturing in segments, then encoding and combining the MPG files afterwards with really good results.
LS -
I still say card. Maybe the signal is not clean enough? This is a BIG problem for digital video. TBC?
I think it could be the cheapo Sounblaster card, but I'm not real sure the Hi8 isn't dying.Originally Posted by lordsmurf
It records perfectlym but to play a tape I have to fast forward the tape for about a minute or two then rewind, then let it play for a bit. It plays, then stutters then plays, Then after a few minutes it smooth again with great picture. I wonder if it is fluctuating enough during playback to mess it up.
Are there some gears or guides that need lubricated? It's never been cleaned or adjusted.
LS -
man, was I pissy in all of this topic or what? I can't beleive you guys still helped me.Originally Posted by lordsmurf
hehe
OK, this is going to hurt.....Smurf....you were right!
I removed the SB Live and used the integrated audio on my MB which had good reviews. Not perfect sync, but I can record 30 minutes at a time now with good sync whereas before I could only do 3-5 minutes at a time.
Now I have a MiniDV camera on it's way and more to learn!
LS
PS Got a JVC GRD94US for $296 shipped.
Capture Help...What do I need to buy.
By thakev in forum Newbie / General discussionsReplies: 3Last Post: 6th Dec 2008, 08:14 -
Which program to buy/use DVDFab, anydvd or are there others that are better
By busterbrown885 in forum DVD RippingReplies: 6Last Post: 11th Nov 2008, 19:06 -
Help To Buy a Movie Program
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 5th May 2008, 13:14 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20
