  1. I have a music video mpeg, Flogging Molly's "The Likes Of You Again". It's 10.1 mb, plays under 5 minutes in WMP just fine, but when I go to burn with Nero I get an error, I try to get TMPGEnc to chew on it, I get an error. I can burn a data disc with just mpegs and my dvd player will play those...not this one among others that work fine. What should I do, I need to at least be able to make a vcd with this thing. Thanx!
    "If it were easy then it wouldn't be a shortcut, it would be the WAY."
  2. What error does TMPGEnc give you?
    Most errors are covered in this section here:
    https://www.videohelp.com/tmpgenc#problems
    Best of luck,
    Cobra
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Indeed. It is nigh on impossible to help you without knowing exactly what error you are getting
    If in doubt, Google it.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Check your mpeg with avicodec and give us a screen shot.
    jimmalenko, your avatar is creeping me out. I keep expecting it to be tgpo.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I thought the mohawk looked pretty cool.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    I like the lightning avatar. It looks more serene !
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That was taken during recent storms in Sydney. I liked it at the time.
