This is what i saw using VirtualVCR
I need some help i got problem when capture this tape
This is an very old VHS tape (abt 10yr already)
I tot of REc it into DVD
But very funny problem WHen i see on my Own TV every thing is look just fine... the problem is when i was abt to capture using PC than show this problem..
I m sure that the tape is fine & ok ..
Isit the Program source cant capture a 10yr ago VHS tape?
can someone help me?
Results 1 to 18 of 18
Hello,
10 years is not very old for a video tape. Try borrowing a svhs vcr with a TBC stabilizer on it. That is the most recommended suggestion posted on this forum.
Hello,
Sorry I don't have a screen shot. The tbc is a special control to stabilize old tapes. I don't have one I've just read about them in this forum. For a full definition check here:
https://www.videohelp.com/glossary
They can be expensive so if you have friend or family member that has one you might try to borrow one.
By the way, I have tapes from before 1990 and they work just fine.
Kevin
--Maybe your tape was of poor construction--Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If the tape plays fine then you should be able to capture it and achieve it to dvd/cd depending on your hardware and software. The age of the source does not matter, it is the condition it is in.
Your computer hardware profile does not list anything but os, so how can we be of help
Assuming that you own the tape and have the right to create a backup achieve copy bear in mind that not all capture cards/devices will bypass macrovision or other copy protection
Please post a more descriptive explanation of problem, don't abbriviate your words and expect us to guess at what you mean. A few extra keystrokes on your part would help
ntsc/pal/seacam ??
capture device
capture software
settings for capture
burner
authoring software
burning software -
This is my system .. i using Virtual VCR to capture into AVI mode..
I dont know what went wrong as i use another brand new tape & try to capture inside video everything is look just fine... but when come to this (10yr old tape) it give me this problem.
On tv everything is fine it happen only when captureing
Operating System: WinXP SP1
CPU Speed: AMD Athlon(tm) 64 Processor 3200+ 2.0 GHz
Harddrive space: 37.27 GB, 111.76 GB
RAM Memory: 1024 MB (28% Utilized)
Video Card: 1280 x 1024 in 32-Bit Color, RADEON X800 PRO Ver.
Capture Card: Pinnacle WDM PCTV Video
Motherboard:
CD-ROM: Asus 50X
DVD-ROM: TDK
CD Writer: Aopen 32x -
A 10 year old VHS tape is a new tape! I have tapes from 1979 that plays OK even today!
BOT (back on topic)
Looks like Macrovision...
Or,wrong capture settings..
Or, PAL60...
What TV system Singapore has?La Linea by Osvaldo Cavandoli
Then: Or this tape is NTSC and the VCR makes it PAL60, or it is Macrovision.
If I recall correct, older Pinnacle cards, used to have bt8xx... So, the btwincap drivers might be a solution (can capture PAL60 and can overlook macrovision).
If it is not a bt8xx card, then Dscaler it might be a capture alternative IF works with this card (rare, but possible).La Linea by Osvaldo Cavandoli
Hi. It looks to me like a NTSC played on PAL or a quasi-Pal recording. Does your capture card support NTSC?
Speaking of old tapes, 10 years is nothing. I've done work with material 30 and 35 years old. And looking again, it's the kind of picture I used to get when watching NTSC satelite feeds on a PAL TV and recording them onto a PAL videotape.
I work with a lot of archival material, and believe, I've seen the strangest formats...
All the best,
Daniel Beller -
If it was NTSC, it wouldn't have colour...
I believe it is PAL60...La Linea by Osvaldo Cavandoli
Originally Posted by SatStorm
Hmm i using 3rd party prog.. either NTSC or PAL it doesnt give me problem with a more brand new tape than this 10 yr old tape
As i try using that program with my capture card to cap PAL or NTSC DVD/VCD format. everything is fine.
Hmm all i know this type is make in taiwan... if this tape is make in taiwan i think taiwan use NTSC format but My VCR player support NTSC/PAL/MESCEAM . Everything play just fine when i watch on TV
It only happen on when i want to capture in to AVI DVD mode.CPU Speed: AMD Athlon(tm) 64 Processor 3200+ 2.0 GHz
Capture Card: Pinnacle WDM PCTV Video -
hmm maybe later i go try again in all kind of format.. hmm will be great if can give me more advice or other prog which can solve the problem? beside spent $$ to get a new vcr =(
Sony said vhs starts to turn to fuzz around 15 years. I don't know if that is the case or not.
If you can get a panasonic dvd recorder, it can copy old vhs with stunning clarity as it has special filters. -
hai.. dvd record cost a bomb over here.. i only have dvd player & dvd writer..
is there other way to solve it?CPU Speed: AMD Athlon(tm) 64 Processor 3200+ 2.0 GHz
Your VCR may have a setting that lets you choose how NTSC tapes are played back. On my sony there is a switch on the back which says "NTSC" or "NTSC playback on PAL TV". This option may also be in the menu of the VCR if your model has one.
"NTSC playback on PAL TV" is PAL 60 mode and is harder to capture.
Change the setting to NTSC output, then capture in NTSC. -
Originally Posted by skeg64
Hmm i try that again tml.. hope it could help me if not i can sit there cry liao at the same time looking for more sourse to solve itCPU Speed: AMD Athlon(tm) 64 Processor 3200+ 2.0 GHz
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Trying to get a good digital capture of an old VHS tape
By StrobeLightEpileptic in forum RestorationReplies: 2Last Post: 21st Nov 2009, 21:16 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 12:56 -
How to capture a full VHS tape?
By burrowsfan in forum Newbie / General discussionsReplies: 11Last Post: 5th Feb 2009, 17:54 -
TV/VHS tape Capture card suggestions for my pc?
By drwho in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2008, 19:49
