    Apr 2003
    i have recently been trying to use my scanner which i have used before and had no problems with it but this time when i open the software that i usually use to scan with (microsoft picture it) i go to the scan section and click the scan button... nothing happens so i close down the app and press the scan button on the scanner itself... again nothing.
    i have tried un/re-installing the scanner but no luck, however the scanner is detected in the 'my computer' section
    when tring to use the cd-rom that came with the scanner i place it in the drive open up my computer and double click the disk and i get a message saying
    16bit windows subsystem
    C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows application. Choose 'Close' to terminate the app.
    I am running on XP Home edition
    I have also checked for new drivers and was told that none were avalible
    Could some1 plaese advise me on what is wrong?
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Did it work before with XP?
    Apr 2003
    yes i have always had xp with this system and the scanner which came with the system and never troubled me before
    EDIT: the scanner is a Packard Bell Diamond 1200plus flat bed
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Have you recently installed or reinstalled any BitCom software.
    If not, you might want to do a complete virus scan for backdoor trojans / worms. I cleaned a machine this morning that kept getting the same message. After cleaning 17 viruses of the machine and removing Bitcom, everything worked fine. Dialer programs in general are a problem.
    Just a thought.
    Apr 2003
    Just a thought.
    Don't think so i have used Bitdefender and have found 19 infected files however not all could be disinfected how can i disinfect the files
    EDIT: i have no bitcom software on this system
    2ND EDIT: Below is the output given by bitdefender, dont know if it is useful in helping me
    C:\Program Files\WindUpdates\WinKA.exe infected: Trojan.KeepAlive.A
    C:\Program Files\WindUpdates\WinKA.exe unable to disinfect
    C:\WINDOWS\Downloaded Program Files\UGO20.exe suspect: Trojan.Downloader.Small.Gen
    C:\WINDOWS\Downloaded Program Files\UGO20.exe copied
    C:\WINDOWS\system32\sc.dll suspect: Trojan.Downloader.Small.Gen
    C:\WINDOWS\system32\sc.dll copied
    C:\WINDOWS\system32\vxiewer.ocx infected: Trojan.Dyfuca.Y
    C:\WINDOWS\system32\vxiewer.ocx unable to disinfect
