whats the best to find out?
i know what you will say, try it ...
i'm planning on 2x42minutes on 1 700MB CDR
so that would be a bitrate of 1032kBits/s
but now the resolution ...
i record in full dvd kwality (MpegII - 720x576 - 6400kbps - 224kbps audio - VBR)
but now i'm looking for a good resolution, wich i cant seem to find
so far ive used 360x240 but then the subtitles looked extremely blurry, and the movie itself also
but what im trying to do now i want to have PERFECT!
so i'm asking your help ...
greetz
Results 1 to 9 of 9
Hello,
Half d1 resolution is 352x480 (NTSC) I believe. That should work for dvd captures.
after trying some resolutions i got from some recordings from a friend & some of my own
tried resolutions:
480x352
480x352, interlaced
640x368, interlaced
640x512, interlaced
720x576, (original)
the original settings came out best ....
atleast thats what i think ... if someone can tell me a tool to take screenshots with for only the screen, i'll post them, so you can see
but is that possible that the original have the best results ... i mean, i never ever saw a rip that was the same resolution .... not even at these bitrates ...
added images -
Are you looking to create MPEG files for playing on a DVD player? Or AVI files for watching on a computer?
Xvid encoded AVI files
i recorded the files as MpegII because of the perfect quality, and now i'm planning to put them in AVI (350MBx2) -
I couldn't view your RAW files. I don't have anything that will open them. Could you post a few as JPG instead?
I convert 720x480 (NTSC) MPEG 2 files to XVID AVI all the time. I usually inverse telecine and reduce to 640x480 for the proper aspect ratio on a computer (and my DIVX/DVD player handles that size well). If I can't inverse telecine I usually use VirtualDub's deinterlace filter and throw away one field (720x480 --> 720x240), then Resize to 640x480 with the Lanczos3 filter. That's rough on subtitles though.
~1000 kbps is a little low for 640x480 frame size unless you have a dark, low motion, low noise source. It looks like you've been trying something close to what I'd recommend: 640x480, 512x384 or 480x360. I would think your subtitles would remain readable with one of the better resizing filters at those resolutions. -
I was almost able to view the file you called 480x352 non-interlaced. I see you are labeling the files with the height first, width second. All the values I suggested were width x height.
ill make some new ons in 100% jpeg quality,
and its width first, then height
but i noticed that when i play them on my TV (using TV out from R9800pro) that the subtitles are almost perfect, as well on lower resolutions ...
Bitrate and resolution advice.
By ShinKyo in forum Video ConversionReplies: 9Last Post: 20th May 2010, 14:01 -
Determine best bitrate for a given resolution
By cd090580 in forum Newbie / General discussionsReplies: 7Last Post: 29th Oct 2008, 17:32 -
Resolution/bitrate for small LCD
By jkleslie in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2008, 14:16 -
Questions about video resolution, and bitrate
By jay_lubb in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2007, 15:46 -
Bitrate Vs. Resolution
By KibaOokaminosuke in forum DVD RippingReplies: 4Last Post: 2nd Jul 2007, 19:35
