Hey,
I've got a problem with dvd2svcd. When i convert a movie, usually an .avi, I want it to be a 2 cd svcd. When I check the movie length and I then look at the bitrate tab it should become 2cds. But often it doesn't It's just a few megs larger like I end up with an extra cd for only 15 mb of video. Anybody know how this is caused or what to do to prevent it?
Hello,
I have read elsewhere that it is sometimes best to lower the bitrate by a value 20 or 30 points less than the estimate of a bitrate calulator. They are good but if your just missing the mark drop the rate a little to have it fit better. The quality hit should be minimal.
If you want to be safe when using dvd2svcd and only want your output to be 2 cd's then just change the number of cd's on the bitrate page from 3 to 2. I've had this happen to me a few times and found that this is the easiest fix.
good luck.Donadagohvi (Cherokee for "Until we meet again")
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
