Hi all;
I am having a problem that I am hoping someone out there can help me solve. I have an Epson R200 printer that I bought to print on CD's and DVD's. The software CD that has the disc printing software won't install.
The InstallShield error pops up in a dialog window and says it can't install, Class Not Registered.![]()
Has anyone else had this or a similar problem? It has me stumped.
I googled the error but haven't had any luck figuring it out.
( note - Win XP Pro, with SP2)
Thanks in advance.
JeeDub
Just because you are paranoid, doesn't mean they aren't after you . . .
JeeDub -
Sorry to hear your troubles but I tend to think that the above is probably the culprit...Originally Posted by JeeDub
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
Maybe the XP SP2 - I have the Epson CD Printing software that came with my R200 and it installs fine.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Just as a follow up, I have figured out and fixed the problem. I am posting the solution in case someone else runs into the same or a similar problem. It seems the installation of the software is controlled by the Installshield system. After some sleuthing on the 'net I found a reference that stated if there is a file or files in the Installshield directory that is(are) corrupted it will never finish the install. The fix is to navigate to and delete the Installshield directory ( normally in c:\Program Files\Installshield or something similar) and then run the install program again. The installation program will recreate the proper directory and files and install the software. I hope this helps.
Peace out.
JeeDubJust because you are paranoid, doesn't mean they aren't after you . . .
JeeDub
Which Direct-to-CD Printing Software Do You Use or Prefer?
By p_l in forum MediaReplies: 4Last Post: 27th Feb 2011, 19:52 -
Freeware software to fix photos before printing
By kyrcy in forum ComputerReplies: 12Last Post: 25th Jan 2011, 15:07 -
Software ideas for full size DVD case sleeve printing please.
By EagleW in forum MediaReplies: 3Last Post: 29th Apr 2010, 01:15 -
Problem Printing DVD Case Insert
By boofer in forum MediaReplies: 7Last Post: 30th Jan 2009, 22:41 -
surething printing software help
By dymx in forum Newbie / General discussionsReplies: 0Last Post: 4th Sep 2008, 11:33
