  1. hello !
    How can i use the subtitles which made in DVD architect prog. , in subtitle workshop prog.When i try to use the ''.sub'' files subtitle program doesnt accept.İf any1 will help with this i ll be so gratefull as we condiser that i have 20 documentary fılm subtitles.
    Thank you for your time.....
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    i am pretty sure you can not use DVDA subtitles in anything else ..
    but the method is to create the disk on your hard drive -- strip the subtitles from the VIDEO_TS folder.
    then you have usable subtitle file ..
