I can burn at 2x perfectly...if I burn a disc at 4x it says it successfully finishes but my dvd player or xbox can't read it...anyone else using an Optorite DD0203 having this problem too? I also have the most recent firmware.
I had that drive and could burn Ritek Go4's perfectly.I have got a new burner but I have just had a bad batch of Ritek's that I ahd to send back.
As it just started to happen? -
Can the Optorite read its own burned disks? In other words, if you put the burned disk back into the Optorite, will it play in your PC on any player that you have (PowerDVD, Windows Media, etc.)?
Will other brands of disk burned on your Optorite play in the Xbox and your DVD player?
The answers to these will give you clues. It just might be a compatibilty issue with these particular Riteks (they might not be as good as other batches) and your Xbox and DVD player. -
Try the latested firmware update . I had this drive for several mo. and found it to be very pickey about the media you used .
No my dvd writer can't even read the discs after burning them at 4x...i've only used 2x riteks and they all seem to work fine
I have the Optorite DD0203 and it has been picky from the start. Very picky. I've been through all the firmware upgrades and currently sit at v2.50. It loved Ritek G04 (4x) media, but then something changed. It was right around the time Ritek started offering cakeboxes instead of shrinkwrap. I could take a disc from an old batch and burn 100%, but a disc from a new batch wouldn't verify.Originally Posted by Hooo3
I finally gave up and got a NEC ND-2500a, which I've upgraded to a NEC ND-2510a v2.16 firmware. It loves my Ritek G04 (4x), G05 (8x), TYG01 (4x@8x), TYG02 (8x). Life's short. I use my Opto DD0203 in another machine primarily to verify the burns of the NEC. It's also nice having a burner on the other machine. It isn't just you.
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 04:13 -
Ritek CD-R White Printable Quality
By mmbetz in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2007, 21:32 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
