when i convert from avi to mpeg2 using 2 pass the video is jumpy the frames dont move cleanly this occurs on all files even high quality files is there a setting i can use to fix this ,also besides tmpgenc are there any other high quality converters for avi to mpeg 2
you say the video is jumpy is that on a stand alone player on on ur pc??? what are the mpeg2 files for svcd or dvd??
Could be a field order problem. Also are you making sure you are converting to the correct mpeg format... i.e. if your avi is pal then convert to pal mpeg or if your avi is ntsc then convert to ntsc mpeg.
Good luck.Donadagohvi (Cherokee for "Until we meet again") -
its for dvd and its jumpy on dvd player and comp and pal and ntsc makes no difference tried both
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
