What's the best way so I can get the right aspect ratio (would like the 720x480 resized to 640x480) all I seem to get is black bars added to a horizontally stretched picture.
The output file size isn't so important, would like to get 8-10 movies (@20-30 min each) per DVD to play on mpeg4 STB.
Thanks - the encoded files came out to just over 400mb each and look just as good as the original DV files.
Just a minor bug report (using .9p version) - after choosing the XviD (mencoder) engine, the ffmpegX progress window displays "encoding to h.264" but I still get a XviD 1.0 file out of it, so just the display is wrong.
Didn't ffmpegX used to support encoding directly from the mov reference file in the iMovie project folder?
Need help can't convert .mp4 file to xvid using VirtualDub
By s_joy09 in forum Video ConversionReplies: 12Last Post: 19th Jul 2011, 06:52 -
What the best format to convert to, AVI(Xvid), MP4 or MKV
By adamf154 in forum Video ConversionReplies: 2Last Post: 1st Mar 2010, 17:48 -
Tool to batch convert xvid to .mp4 for iPhone.
By Floob in forum Video ConversionReplies: 8Last Post: 14th Sep 2009, 13:20 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 04:53 -
How do I export an iMovie project to DivX?
By tren in forum MacReplies: 8Last Post: 17th Jan 2008, 16:44
