Using DVD Shrink, I've backed up a lot of full length movies, but I never backed up episode disc sets. I want to backup my Chappelle's Show Season 1 (not on one disc), but I want it at the best possible quality with the menus. DVD Shrink automatically gives compression at 58.6% and I want better.
Any ideas on this disc or episode discs in general? I'm open to other DVD ripping/copying programs that may get the job done.
TIA
I think maybe VOBBlanker or TitleSetBlanker might do what you require. What you can do is make two DVDs out of the one original. Say for example Disc 1 in your Box Set contains 6 episodes. You could have 3 eps + menus on one and the remaining 3 + menus on the other. All menus remain functional too.
If in doubt, Google it. -
Thanx
But I don't want 4 discs for this 2 disc set. I'm going to try the full backup at 56%
thanx again. any other suggestions would be appreciated -
I would suggest you use DVD ReBuilder then, it uses CCE for its encoding and will give you better quality at 55% than Shrink will.
CM -
You can have lower compression ratio if you remove things you don't need from the disk, like studio logo, credits, etc
Many episode disks have duplicated material (like credits for each episode). You can use DvdReMake Pro to keep only one copy and "reuse" it in all episodes.http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
name of episode
By maxone71 in forum DVD RippingReplies: 1Last Post: 13th Mar 2012, 02:47 -
title of episode
By maxone71 in forum DVD RippingReplies: 1Last Post: 13th Mar 2011, 04:37 -
TV Series, more episode length files than episodes on disc.
By Mick1988 in forum DVD RippingReplies: 2Last Post: 1st Jan 2010, 09:58 -
Error backing up brand new disc
By pugvader in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2009, 19:25 -
Arghhhhh backing up a KARAOKE CD+G disc
By the-doctor in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2008, 23:06
