hey all,
For some reason, whenever I try to open an MPEG using either Windows Media Player or Winamp, the video plays for about 20 seconds, freezes, and then i get a message saying that my internet is no longer connected. i have windows2000 server edition, and i have an ati dfe 530tx+ video card. any help would be greatly appreciated.
thank you,
gurnett
why are you using server edition ?
it is not good for multimedia use - unless you twidle with a lot of settings -- it is also slower to use than pro workstation versions ..
it is also expensive .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I recall a similar instability when I was running 2000. If you're running Winamp, make sure it's version 5. Apply the appropriate service packs.
Move the LAN card to another PCI slot. Also, certain motherboards have a crashing problem when the sound card on the motherboard is used.
Does your completely freeze when the network connection drops? -
it is not more stable -- it is the same code base as workstation -- in fact you can turn into another ..
if anything it is MORE unstable because if you don't know about the extra services it is running - lets just say you can be very surprised -- many anti virus and home firewalls don't work or work proper on server version ..
it is a expensive program -- i am curious how you got it for free ...
as i stated - it is poor for any multimedia use - unless you go in and rape and pillage it and basically turn it back to workstation ...
we have had to use adv server on quad xeon cpu workstations -- and it takes a lot of set up to make them useful .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
well, it wasn't really the intention of this post to discuss the stability of Windows2000 server, but i just swapped video cards with one of the other computers i own and everything works fine.
send video to TV over ethernet?!
By kevbodian in forum Video Streaming DownloadingReplies: 17Last Post: 22nd Dec 2011, 21:13 -
Printing Video Stills with Mac and old ethernet printer
By HowardNeedsHelp in forum MacReplies: 14Last Post: 2nd Apr 2011, 20:31 -
[SOLVED (?)] Opera 10.6 and higher, ¿ conflict with old video driver(s) ?
By El Heggunte in forum Off topicReplies: 1Last Post: 16th Feb 2011, 21:07 -
Ethernet Video Card?
By liquid885 in forum Media Center PC / MediaCentersReplies: 8Last Post: 12th Jul 2010, 21:15 -
receive live video from TV tuner and stream it via Ethernet
By mb508 in forum Newbie / General discussionsReplies: 5Last Post: 21st Sep 2007, 06:53
