Just wondering if any one has had any problems backing up Man On Fire.
I backed it up with DVD-RB and CCE and noticed thru out the movie there was a lot of pixelation. So I gave DVD Shrink a shot and ended up with same results. The original plays just fine no pixelation going to try backing it up on another pc.
I think it depends on if you have a borderline DVD.
My wife got a set of Little House on the Prairie DVDs and they are marginal, but no pixelation. They crammed four 1-hour episodes (45 min. ea. without commercials) onto each DVD, so they're not the best quality.
Trying to back them up with DVDShrink puts them over the edge, and all sorts of compression artifacts show up, like jerkiness, leaves and grass in the background that seems to vibrate, lots of nasty stuff. The backups are unwatchable :P -
Same results on different pc, they play just fine but I havent seen that much pixelation on a backup in awhile.
no problems here either. used dvd shrink deep analysis movie only....
How Big A Boy Are Ya? -
No problem coping the complete disc with shrink with the enhanced settings. Plays perfectly
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2011, 23:11 -
The forgotten Fire
By Dr.Gee in forum Off topicReplies: 0Last Post: 14th Sep 2009, 20:09 -
"Man On Fire" AviSynth SFX?
By meldavid in forum EditingReplies: 0Last Post: 18th Jan 2009, 10:19 -
Tapes in a fire
By Des in forum RestorationReplies: 0Last Post: 3rd Oct 2008, 11:28 -
Great Ball of Fire!
By retroborg in forum Off topicReplies: 16Last Post: 1st Jun 2007, 11:26
