Hi there
I got some old DivX movies and they have 11Khz mono audio track.
I'm trying to convert the audio to 48Khz using Virtual Dub with LAME mp3 encoder or Radium Fraunhofer mp3 encoder.
The problem is that after conversion I get audio with bad quality with ringing problems as well.
How can I convert DivX audio from lower sampling rates to 48Khz without any quality loss.
Results 1 to 11 of 11
umm..
at 11khz the quality has set sail long ago...
your best bet would be to get quality by either buying the dvd or the vhs tape and capturing it. -
If you are keeping these as divx files, then there is no point resampling. As muskgrave said, the quality is already gone.
If you are converting to DVD, then try goldwave and export to (save as) uncompressed PCM wav files. Then use these wav files as the audio source when you encode to mpeg-2. -
The reason I HAVE TO convert these to 48 is my DivX/DVD player won't play DivX with audio less than 44Khz.
I need to convert so I can see the video. The problem is that when I covert to 48Khz, I get this trebbly ringing effect on top which sounds like crap...
I need to find a way to convert without the ringing.. -
...or use ssrc
/Mats -
Yes, I fully understand. I also understand that as MP3, you can't do a thing with your audio as MP3, except listen to it. And no, the mp3 isn't encoded at 11 kHz, the wav encoded as mp3 is sampled at 11 kHz.Originally Posted by sfx70
What you have to do, is extract the mp3 audio using VirtualDub direct stream copy.
Load it in GoldWave and upsample to 48 kHz (or whatever) and save wav, or decode mp3 to wav, upsample with ssrc.
Load original AVI in VirtualDub, select WAV audio and select your upsampled wav. Set video to direct stream copy, audio to desired compression (mp3 128 kbps?) and Save AVI.
/Mats -
Agree with Mats method except the 1st bit. Goldwave will open your divx avi file directly, no need to use virtualdub to extract the audio 1st.Originally Posted by mats.hogberg
Quite true. Keep forgetting that, even if I use that method frequently!Originally Posted by bugster
/Mats -
I got a similar solution before I even looked at the posts which I thank all of you for.
I use Sound Forge import the DivX, upsample and then save as MP3.
Use VirtualDubMod to add the Mp3 as a stream (delete the original audio stream) and save as Direct Copy for Video.
Finally.. phew..
Need to resample PAL audio to NTSC audio. Is it possible?
By mob in forum AudioReplies: 8Last Post: 28th Jul 2013, 23:51 -
How to resample the audio of a WMV file ?
By turbo20010 in forum AudioReplies: 22Last Post: 13th Jan 2011, 13:21 -
Convert at Low Bitrates at 48Khz in Stereo
By ashwin.terminator in forum Newbie / General discussionsReplies: 23Last Post: 23rd Jul 2009, 18:13 -
Avisynth "ssrc resample audio" help
By DaneClark in forum Video ConversionReplies: 0Last Post: 11th Jul 2009, 00:50 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 18:22
