Is it possible to get clips out of a DVD to use in making a compilation DVD (for example, great comedy scenes from various movies)...for personal use only? I have FCP4 and DVD Studio Pro 2. Thanks for the help.
Decrypt the DVD with MTR and then use DVDxDV to extract the scenes you want. Then import them into FCP.
You can also use Cinematize to do this, or a combination of around 4 or 5 freeware tools one after the other.
need help regarding dvd clips
By lullaby49 in forum EditingReplies: 1Last Post: 13th Mar 2011, 04:28 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
Clips for DVD's?
By pianoman1976 in forum MacReplies: 2Last Post: 30th Jan 2009, 20:52 -
What is the best way to gather clips from various DVD's?
By JediPM in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 11:30 -
How to make clips from a DVD?
By Soccerman77 in forum EditingReplies: 2Last Post: 12th Oct 2007, 06:44
