ANSWER HERE
Originally Posted by mats.hogberg
Sheesh !
The easiest way to test if your settings are correct is use the source range function and set it to do a 30 second or 1 minute sample encode and let it run right through till it is finished. If you are confident your settings are right then you just untick the source range box and let it go to town.
Results 31 to 32 of 32
If in doubt, Google it.
Try this.
The files may have been 'temporarily' stored in the Temp folder. This is usually C:\Documents and Settings\'Username'\Local Settings\Temp.
Click on Tools, Folder options, View and then scroll down and click 'Show hidden files and folders'. They may be in there.
If you are doing VBR and then first pass is only analyzing. If it crashed then usually any temp files would be deleted. Just check the size of your hard-drive, as it suddenly reduced? If so, they should be there.
I always create a folder, give it a name and then i know where anything and everything will be, if a problem occurs. It's just tidier and easier for me-maybe a thought?
Cannot find DV output pin
By RalphW in forum Capturing and VCRReplies: 11Last Post: 23rd Jan 2024, 15:14 -
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
i cant find a way to output sound from my tv
By wapfuture in forum AudioReplies: 3Last Post: 26th Mar 2010, 11:49 -
Can't find H264 in TMPGEnc?
By Mizzle in forum Video ConversionReplies: 0Last Post: 30th Dec 2009, 17:24
