Is Daemon Tool the best software for complete newbies to create virtual CDs? I read their forums and I'm horrified by their software complexity and faults. I need a simple solution, your suggestion is appreciated.
Daemon Tools doesn't create the images, it will only mount them. For creation, it depends on the type of disc... For DVD's, I like DVD Decrypter, for normal CD's, ISOBuster, for copy-protected game CD's, Alcohol 120%. As far as Daemon-Tools for mounting, there's nothing better imho.Originally Posted by webmal
Circle Virtual CD works for me (used to be Hekko), it's free so give it a try. You can get it at Download.com:
http://www.download.com/Circle-Virtual-CD/3000-2248-10256516.html?tag=lst-0-1Old home videos are historical documents that may be best used to annoy your children. -
Deamon tools is what I used for a short time, don't remember if it was a trial or free or what.
Was not hard to use, make ISO of your disk and store it on the hard drive, select it and open (mount) almost the same as anyother file with any other program.
I only used it a short time, had no use for it and don't even have it now.
But it was easy as could be and seemed to work very well.
Now thinking about it, I did have and use a friends system though about that time also while he was traveling Europe. It might have been on his system that I used it.
Software to create mp3 audio CDs
By 1234567 in forum AudioReplies: 5Last Post: 5th Jul 2011, 20:52 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
Why Don't Double Layer Discs Work?
By GordRocks in forum MediaReplies: 14Last Post: 10th Feb 2010, 09:16 -
QUERY: editing CloneCD images & best for game data & music CDs
By andwan0 in forum Newbie / General discussionsReplies: 6Last Post: 18th May 2009, 21:12 -
Wall Street NASDAQ virtual stock trade game
By Dv8ted2 in forum DVD & Blu-ray WritersReplies: 0Last Post: 26th Apr 2009, 09:36
