guys i have this vcd mpeg that tmpgenc cant open or any other encoder come to that , it plays on the pc ok which is strange coz i thought if it would play ok on a player then an encoder should be able to open it
its mpeg1 xvid , gspot returns codecs installed for video and pcm for audio , direct show render only shows audio , nothing in the video path line ?
i extracted it from a dat with vcd gear and used the mpeg fix , just incase any errors where in the file , i have also used mpegvcr to check gop as a kinda last resort , but if i try to do anything else in mpegvcr with the file it just hangs
what is happening do ya rekon ?
Direct Show Priority not set high enough:Originally Posted by gilbates
Hello. -
cheers m8
nice screen cap too
direct show is tops already m8
any other thoughts ! -
if its any use ( prob not ) but when the file is accessed by any app it maxes out the cpu and i have to shut down explorer and then restart it to get the cpu back to idle
i have checked it for viruses and its clean , as i stated before it plays and looks fine in media player classic or core media player -
Even though certain of your applications can play it, try to install another mpeg codec form the Tools section at left.
Hello. -
cheers tommy
i actually kinda did that from avi codecs web link on the audio line and i installed from that link the nimo50 codec pack , whatever it installed or replaced sorted me out m8 and the file is now behaving
i guess just a bad codec on my machine somewhere was the culprit
thanx for your thoughts
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 09:41 -
FFmpegX Wont Convert The Way Its How-To Says
By jonh2o in forum MacReplies: 3Last Post: 14th Feb 2008, 08:37 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56 -
DVD wont convert small enough
By jweihs in forum Video ConversionReplies: 7Last Post: 17th Jul 2007, 14:28
