  1. Hello!
    I burned a dvdr from another dvdr, fisrt with dvd decrypter to rip the vobs and others files and then i burned them with Nero, everything worked fine, burned was ok, but when i play the new dvdr in my home dvd player it crash everytime, so how do i know if the original dvdr has bad sectors?,it works good in my home dvd player,,,,anyone know what can i do?, thanks in advance
    Apr 2002
    The State of Frustration
    The original DVD, was a commercial original, does it have any physical damage?What's on it, or better, what should be on it?
    Hello.
  3. no, it is a dvdr, i dont see anything, it works very good on my dvd player....
  4. If the source was a dvd'r. You would be better using iso mode in dvd decrypter to read then write.
    Could also just use nero to copy the disk....
    As to why it wont play in your standalone it could be it does'nt like the media you have copied onto.. + or -
    Not bothered by small problems...
    Spend a night alone with a mosquito
