I am a beginner's amateur, just bought Videowave Professional 7, and can't seem to get past square one. A friend gave me a documentary on a political debate about 90 min long. I want to edit about a dozen clips from it, put them in a storyboard production, burn it onto a DVD, and show a 15 min DVD to my reading group. He said it wasn't protected material, but had me decrypt it anyway - and it came out in VOB, BUP, and IFO files. So I open up Videowave 7, and to make a storyboard it says go to production editor. When I clicked on "Create New DVD" it didn't give me the production editor, so I clicked on "Edit Video" and found the production editor. The source DVD has the program in about 11 files and folders inside "MyDVD" folder. The help guide then says to go to Media Selector and browse for video clips. When I try to highlight any of the 11 documents, or the whole MyDVD folder, it won't drag into Panel 1. Those are my video clips aren't they? files like VTS_01_03.VOB ?
I'm not sure what I am doing wrong. Any help would be appreciated.
sincerely, gareth
Many editors will directly open .VOB files, but it sounds like yours doesn't.
Try renaming the .VOB files by changing the extension to ".MPG" and see if you can open and edit them.
If not, you can always use Vobrator or a similar program to demux the video and audio streams, then open them separately in the editor, and have the editor save them as whatever file format you want. -
Womble mpeg video wizard will accept vob's. You can do some nice editting effects and it will output as mpeg.
Edit a VOB without Intermediate Files
By Guiboche in forum User guidesReplies: 43Last Post: 1st Mar 2009, 22:17 -
edit .VOB files
By vali in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2008, 04:23 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 12:12 -
Playing ISO and VOB files directly to TV
By indiraider in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Oct 2007, 01:29
