When I installed sp2 I originally thought my only problem was Nero 6 (which was fixed with an update) but then I find I am dropping frames like crazy (265 dropped in a 40 second capture). I checked the Pinnacle site and the MS site and the only thing they mentioned was an error message when accessing an mpeg file (and Pinnacle is working on that), so this is something that may be specific to my setup, maybe not. I reverted back to my last SP1 backup and everything is back the way it should be, no dropped frames. Just wanted to give you a heads-up if you use Pinnacle Studio 9. I'll wait a while to see if this is fixed before reinstalling SP2. I really hate that, because there were some things that were improved, in my case, when I added the SP2. Anyone else experience this?
If it works, don't fix it.
Thanks for the heads up, another reason to hold off on installing sp2
man'o'man,the list of programmes conflicting with SP2 gets bigger every day,like you say,another reason to hang back on installing Microsofts glorified firewall.
I had problems the minute I installed SP2...promptly removed it. Simply annoying. That whole auto-update nonsense is completely infuriating. Microsoft really needs to get they're sh!t together.
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
Windows XP SP2 capturing problem
By superdud1400 in forum Capturing and VCRReplies: 4Last Post: 23rd Jun 2008, 01:50 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 02:03 -
Auto play problem in WinXP SP2
By bevills1 in forum ComputerReplies: 4Last Post: 3rd Mar 2008, 12:09 -
Problem installing Sony HDR-SR1 on XP.SP2
By erik010 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st Jul 2007, 07:40
