  1. Hi guys!
    I had made a bad dvd on a rewriteable dvdrw, witch software do you recommend me to delete my dvd?. I had tried with Nero but it doesnt work, it says it is not a dvdrw, but it is....any suggestion?
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    try formatting the dvdrw.
    you will need to use the format option to erase the disc in nero
  3. Member SaSi's Avatar
    Jan 2003
    Hellas
    I what way is it a "bad DVD"? Bad authoring or failed recording?
    In the second case, it may be ruined, but try DVDInfoPro. It allows you to erase the disk. With Nero, a badly recorded DVDRW has better chance to be revived by a full (rather than quick) format.
    The more I learn, the more I come to realize how little it is I know.
  4. it is a hp invent dvd+r rw i will try with dvdinfopro thanks. I think it is a failed recording but it finished ok in Nero when i had burned it.
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    Be careful with those. I twice had a +RW record perfectly but fail during verify (files unaccacible). Erase them fully often. This seems to "recover" marginal media.
