Hi, i recently bought a new dvd player for my room, I burnt some VCDs and they seem to play fine, but i downloaded some SVCDS and burnt them using nero, and when i play them, the audio isnt in sync with the video, its not in time.
what can i do to fix this?
i burnt the svcd as PAL when some of the SVCD files were NTSC, is that why? but my player plays both pal/ntsc.
Plz help!
That could be your prob, if your player does both then burn the discs as what they are.
I just played the svcd on my computer and it works fine, but not on the standalone...
hm
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 16:28 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
