When I try to split AVI files, I get the following message."Virtualdub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatability. This may introduce up to 17535 ms of skew from the video stream." If I press "OK", it splits them for me, but the audio/video sync is not right when completed. I would think maybe its the particular AVI, but it happens with every AVI I try it with. It didnt always do this, I used to be able to split with no problems. Can anyone help? Thanks
Splitting and Rejoining Video Segments with Virtualdub
By unclescoob in forum EditingReplies: 4Last Post: 30th Oct 2011, 09:43 -
a problem with virtualdub when i try to convert mkv to avi
By romanch in forum Video ConversionReplies: 6Last Post: 23rd Jun 2009, 23:41 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 15:44 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53
