  1. I must be starting to sound dumb here, so bare with me !
    All ( or most ) of the MPEG files I obtain to burn into a VCD, are nearly always already encoded into NTSC VCD format ( 1150 kbit/sec MPEG-1
    352 x 240 pixels 29,97 frames/second ).
    Yet when I out them into VCDEasy , there always seems to be a problem with them. They either require padding or after a specific frame number the data will be lost etc.
    During the download process are the files becoming corrupt ? and is there a simple basic MPEG fix program that returns them all into standard VCD compliant mpegs streams ?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    They might be of VCD spec, but not multiplexed as VCD. That's what makes VCDEasy pads the stream.
    Multiplex the mpg using mpeg tools in TMPGEnc as Video-CD (non-standard).
    /Mats
  3. Originally Posted by mats.hogberg
    /Mats
    I have taken on board your advice Mats and use the Simple De-multiplex option and then Simple Multiplex selecting MPEG-1 Video-CD. So far it seems to work and no errors have been reported in VCDEasy. But I still am having issues with some VCD's not working in my Sony DVD player that has the latest firmware revision and should ! play VCD and SVCD.
    My other DVDF player will play just about anything I chuck at it ......except its the kids
    I take it that MPGEnc is still the best option to De and Re multiplex these MPEG streams ?
