Well I converted my first Divx to DVDr and it turned out pretty good. I used TMPGEnc Plus and used the wizard and convert to mpeg. and then used TMPGEnc Author and converted to VOB. I even made chapters and the quality seem to be as good as the Divx. I was impressed especially for as little reading as I did. So here's my question, in converting the Divx to Mpeg TMPGenc I had to toggle between audio of CBR PCM or Mpeg-1 Layer 2(or someting like that) and also VBR. I pick CBR Mpeg-1 audio. It worked, but is one better then the other? Is one more compatible across a number of DVD players then another? Thanks.
There are 4 types of audio allowable under the DVD spec, and some of these have subsets. The main types are
1. LPCM - uncompressed audio stream. Eats lots of space. Playable in anything
2. Mpeg1LayerII - good compression, playable in all PAL standalone players. may or may not play in NTSC standalone players.
3. AC-3 (Dolby Digital) - 1 - 5.1 channels. very good compression. Downsamples to stereo in stand alone players if required.
4. DTS (Digital Theatre System) - 5.1 - 6.1 channels. Good compression, but not as good as AC-3. Requires a dedicated decoder chip in the player or the amp as it does not downsample to stereo.
If you have an hour or less of video, LPCM is probably acceptable. If you have more than this, you may find the sacrifce of video quality required to accomodate the audio isn't worth it. Mpeg1LayerII is a good solid compromise for stereo audio, if your player wil accept it. I'm in PAL land, and have never had an issue with it.
My preference is AC-3. High quality with good compression, and allows for 2 channel stereo audio. You can get a cheap but good AC-3 decoder from pegasys to go with tmpegenc/DVD Author. A worthwhile investment.Read my blog here.
DVDR's with hdd question
By tannenba in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2011, 12:43 -
Divx\Xvid 2 DVDR
By eliqush in forum DVD RippingReplies: 9Last Post: 14th Jul 2009, 08:48 -
Philips Recorder DVDR 5570 - DIVX subtitles not copied and not displayed
By Radio1040 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Mar 2009, 01:18 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 03:28
