  1. When I encoded with 2-pass option, it took more time but I can't see any different in the quality. Can I always do it with 1-pass?
    Jun 2004
    Peterboro U.K
    Basically its up to the individual on what quality you want. Someone will quote me if i'm wrong but i understand it when you do a 2 pass high action parts of the film will get more of a bitrate than low action therefore making high action more clearer. On 1 pass the whole film is at a constant bit rate all through.
  3. One-pass has three modes:
    - CBR (Constant Bit Rate) - uses the same amount of data regardless of complexity
    - VBR (Variable Bit Rate) - uses less data for a simple scene and more for a complex one
    - Quality based (VBR) - tries to maintain a set quality level
    These files could end up any size, except CBR where the filesize can be accurately predicted. They also do not yield the quality of two-pass encoding.
    Two passes allows the encoder to find complex and simple scenes and allocate bitrate before it actually encodes. This means that:
    - Bitrate is used much more efficiently, resulting in a higher quality file
    - A certain filesize can be obtained accurately
    Cobra
