how can I tell how much cache my HD has ?
Results 1 to 10 of 10
The easiest way I can think of is to look it up in the specs sheet on the manufacturer's web site. A quick Google search with the Manufacturer name and model number should answer your question.
Offhand, I don't know of any test you can do on the drive itself to find out how much cache it has, although there may be a way (I've never looked in to it).Ethernet (n): something used to catch the etherbunny -
Ditto the mfg. specs. That's the easiest. If you can't find the model number in Device Manager, a diagnostic app like Sandra might show it.
make sure you get the model correct/complete
I replaced my old 40gb harddrive witha Western digital WD120JB w/8m buffer. couple weeks later a friend decided to do the same, and sent me a email to say he got a better deal($12.00 less than i spent). his drive is a WD120BB w/2m.
although i gave him the exact model and a link to the vendor i bought from, he went to pricewatch and only looked at capacity, and price. his drive works fine, but the JB vs BB is a hefty buffer size difference.
and Sandra will show you as well.Be satisfied, the day is yours. If i have to explain, you would'nt understand. -
Originally Posted by xxgriff
It goes to show you that you can lead a horse to water .......
I would have gladly paid the extra twelve bucks for the larger cache. -
I serached around for my drive and all I can find is 2 drives with the same name and one is 2MB and one is 8 MB I think I got the 2 MB one but I'm still having troubles finding out.
Mine is a
Maxtor 6Y120L0
any any ideas ? -
Nothing can stop me now, 'cause I don't care anymore.
Thanks thats what I thought, ph well I'm going to have to get something bigger with the 8 MB Cache and give this one to my daughter.
Cache videos without prompt
By jwbrasil2 in forum Video Streaming DownloadingReplies: 3Last Post: 18th Sep 2011, 17:44 -
Cache Live Video Stream
By Algernon62 in forum Video Streaming DownloadingReplies: 0Last Post: 5th Apr 2011, 13:46 -
Cache storage of flash video?
By smooth88 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Apr 2010, 22:27 -
Vista Thumbnail Cache
By Anurag in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2009, 01:08 -
L2 Cache question
By Seeker47 in forum ComputerReplies: 1Last Post: 23rd Jun 2008, 14:20
