Is there a way I can create an image from a scene off one of my DVDs and get good picture quality? Basically I want to be able to load the vob into a program (not sure which) then take like a screenshot and use that to print onto my DVD. Is this possible? thank you!
Yes but the quality isn't going to be that hot, it's a relativley small source image. As I pointed out in another thread if it was a digital image from a camera it would be .35 megapixels. Most media players such as power dvd, editors, capture component in a still image app will do that. Not sure but MS'S media player probably will too.
Edit: I just looked it appears MS's player doesn't do that. -
play your DVD on your PC using any DVD player
press Print Screen on your keyboard...
Open Paint or Paintbrush
then press Ctrl + V (hold down Ctrl, then press V while holding down Ctrl) on your keyboard
edit...hacking the Net using typewriter :D
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 07:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29 -
How to post an image instead of a link to image?
By fLYtRap in forum FeedbackReplies: 11Last Post: 5th Jul 2007, 12:55
