I think i made a mistake splitting a MPEG.
i have a NTSC Video CD Movie and i splitted in with TMPGEnc.
But i think i forgot to change the "Type:", i think i left it as MPEG-1 System (automatic) instead of MPEG-1 Video-CD.
It plays fine on my computer but will it not be compatable with my DVD player now? I checked it Virutal Dub and it still had all the NTSC settings (352x240 29,97fps), but since i forgot to change the Type in TMPGEnc will it not work in my DVD player?
Thanx in advance.
im sorry to tell you that it cant i made the same mistake and it wouldnt play..i was sooo pissed off.....wwhy dont you just cut the original mpeg again
If you don't have the original anymore, don't worry. Just demultiplex and remultiplex using the correct Type.
MPEG "cutting" is nothing else than demultiplex/ multiplex. -
Is there a program that can check whether it's a proper NTSC MPEG or not? Because I think I might have made the mistake on more than 1 file.
try loding it to Nero and when it loaded right click on the mpg and see its properties and it should say if it complaint the frame rate and if its PAL or NTSC ..hope that hleps
Help with splitting
By stinger161 in forum EditingReplies: 1Last Post: 29th Oct 2009, 18:58 -
Help! Splitting a DVD
By StrikerZERO in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2008, 20:19 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
Video Splitting?
By xcape in forum EditingReplies: 3Last Post: 10th Jul 2007, 19:06 -
cutting and splitting
By ichigo15 in forum EditingReplies: 1Last Post: 18th Jun 2007, 21:01
