Can anybody help on this slight but annoying thing? I can capture fairly well using iuVCR (latest beta version as it`s more stable) at 384x288 at 24 frames/second as an uncompressed AVI.
Only trouble is even with a defragged drive I lose on average about 24 or 25 frames per hour of capturing and it`s more noticeable at the end of the file with the sound jumping forward in time so to speak. I have 640 meg and an athlon 1.4ghz but I`m sure it cant be that as I`m dropping a minimal amount of frames so can anybody recommend a program that can sort this out? Only other one I use is media studiopro 7 which is no good. Any help will be more than gratefulcheers
Results 1 to 1 of 1
Aldi Tevion DD1018 MacroVision setting
By tevionShopper in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 06:14 -
Tevion TDR930 DVD Recorder Problem
By markw6796 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Mar 2009, 16:40 -
Aldi/Tevion DVD recorder "HDD DVD 160 MkII" - tech info, region f
By fzabkar in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Jun 2008, 21:04 -
Problem with Tevion HDMI DVD player
By Buna3000 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Oct 2007, 11:43 -
tevion hi fi with dvd player model TMHF910 from aldi (hack?)
By jgalvao in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th May 2007, 10:19
cheers
