hi all, i want to create a dvd using 2 dv tapes i have, i want to join them to create 1 seamless dvd, can ne 1 shed n e light on how i go about this?
ta
1. Transfer the dv tapes to the harddrive.
2. If you need to make any edits, do so with a Video Editing Program.
3. Convert the avi files to mpeg2 format. DVD compliant files.
4. Author the dvd with a DVD authoring program.
Those are the steps I use. There are guides in this website that
I have used and I have eventually developed my own process.
Good luck.When it sounds too good to be true, it usually is!! -
If you just want them to play one after the other, the authoring program will do that. They will play seamlessly. No need to combine them before.
VHS Tapes - Fixing video that keeps "rolling"??
By RobV in forum RestorationReplies: 7Last Post: 22nd Nov 2010, 02:18 -
Ulead Video studio 10 "create DVD"
By kiethpenny in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2009, 17:40 -
Methods to fix "eaten"/crinkled VHS tapes?
By lordsmurf in forum Capturing and VCRReplies: 16Last Post: 26th Mar 2009, 15:22 -
Need help RE: "stuttering" audio on older DV tapes during capture
By seaoharewhy in forum RestorationReplies: 9Last Post: 11th Apr 2008, 08:44 -
Need To Create "Chapters" in Audio DVD
By urdivine in forum Authoring (DVD)Replies: 6Last Post: 25th May 2007, 00:06
