I want to be able to rip CD audio disc images to my hard disc in the shortest time frame possible.
What does this mostly depend on?
1. the read speed of my cdrw (52x is the highest I have heard of)
2. the cpu speed of my PC (sadly I am stuck with an AMD 1.5 ghz machine)
3. the ram in my PC (have 786 mb)
thx.
Tygrus
If you are ripping complete images/isos, I would recommend Blindwrite software it's the fastest I've used.
If you wish to rip individual tracks to wav/mp3 the fastest I've used is
CDRfe >
http://demosten.com/cdrfe/
The specs you list should easily be adequate to rip at highest speed.
One thing to remember though, cdrw's have different audio extraction speeds that will alter rip speed when ripping tracks as opposed to iso/images which should be fast with any 52x.
Ripping DVDs that contain still image / picture as video
By vdgg in forum DVD RippingReplies: 11Last Post: 8th Jan 2012, 14:05 -
ripping blu ray software without image
By ShinjiIkari1990 in forum Blu-ray RippingReplies: 1Last Post: 12th Jun 2009, 22:34 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 17:57 -
Fastest way to burn using DVDA 5 - disk image or DAR file?
By jakgeoffsub in forum Authoring (DVD)Replies: 2Last Post: 11th Feb 2009, 23:29 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
