  1. Hi, I'm looking at Cases for a computer.
    Here's what I need:
    1) Enough power for 2 HardDrives, DVDRW DL, CDRW/DVDROM, good cooling, AMD 64, GeForce 6800, RME Hammerfall 96/54, Maybe a second sound card, and what ever else it may need to power that I can't think of.
    How much power is that? or WATTS I mean.
    2) LOW noise. I want to record audio with this thing and need the computer to be as quite as possible, I don't know how much the case affects this but any info on low noise componets would be helpful.
    3) Good Cooling, I'm leaning in the AMD 64 range, I hear they run hot and need good cooling so my computer runs for years and years to come. Also there will be alot of expensive hardware inside it, I need every thing to be safe as can be in terms of cooling.
    How does the material the case is made from affect everything?
    I also require USB2, firewire ports and enough room for DVD burner, CD burner, and 2+ Hard drives.
    Any help would be great.
    Apr 2004
    Hudson, Florida
    Antec cases are nice, they don't come with all the bells and whistles, they let you upgrade. I'm actually putting a computer together with an Antec SOHO 1000AMG, it's amazing. 430W will do for a power supply. Sorry for being vague, AC is out and I'm working on two computers. It's a little under 100 degrees.
  3. are you buying a boxed retail CPU? if so you will get a heatsink/fan. i admit there are better heatsinks, but if you are not going to OC the AMD heatsink/fan will work fine. if you buy OEM then you will have to choose a heatsink fan.
    a 430w or better power supply would be a good start. while lower rated PSU's may handle the load, it is a good idea to have some headroom.
    again there are reviews that will provide useful info on every component, powersupplies, and cooling included.
    some cases will come with a power supply, and some do not. i have a Antec 430w in a Lian Li case for my main box (i got a great deal on the combo), but also have used Antec, Enermax, SilverStone, and In-Win on occasion for myself and when building for others.
    research every component, and decide what you want/need, and can afford.
    some sites that review:
    www.anandtech.com
    www.tomshardware.com
    www.aceshardware.com
    www.hardocp.com
    there are many, many more sites to read more.
    Be satisfied, the day is yours. If i have to explain, you would'nt understand.
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I bought my last two cases from these folks and have been very happy with the price / service. They aslo offer a section on "quiet PC's".
    http://www.directron.com/
    They carry just about every case made at fairly resonable prices. They ship fast. I strongly recommend aluminum cases with a good power supply in the 400 - 450 watt range. Antec and Enermax are great. I use the Enermax because they offer dual directional cooling and variable power supply fan speed.
    Here's a link to a PC watts calculator:
    http://www.jscustompcs.com/power_supply/
  5. Mod Neophyte redwudz's Avatar
    USA
    I like the Antec cases. I use a medium server case. Two exhaust fans in the rear and an intake that blows over the HDs. Lots of room inside. Rounded IDE cables help, also.
    I run 4 HDs, CD and DVD burner, DVD ROM, ZIP drive with a quality 300W supply. I would recommend a 350W - 400W, though. I've seen cheap 450W supplies that put out way too much heat. Buy quality.
    If noise is really an issue, you can get a case that uses 120mm fans that turn slower, also quiet power supplies and quiet CPU coolers. As long as you aren't overclocking, heat is usually not a big problem.
    I too recommend the sites xxgriff listed.
    As far as steel VS aluminum; Steel is generally quieter, but with a quality case, probably not that much difference.
  6. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Easy. Antec NeoPower 480W power supply coupled with either a Lian Li PC-1000 or an Antec P160. That combo should pretty much do you for quiet, cool, and powerful.
